Activity Forums Adobe After Effects Help! AE Rendering problem…
  • Help! AE Rendering problem…
    Posted by Greg2006 on August 30, 2006 at 10:23 pm
    Comp work area selected is not rendering correct frames: there is no time remapping or time stretching in the comp or any of the sub comps and the only way to render correct frames is to save a RAM preview – all other render output options through the render queue result in different areas of the comp being rendered. Has anyone come across this issue before?
    Mark replied 20 years ago 2 Members · 1 Reply
  • Mark
    August 30, 2006 at 11:40 pm
    In your render queue, in the export moduel, you can set a time frame from which to render…..maybe your template is not set to workspace, but rather to a specific time.
    Mark
