Help: AE 6.5 Tracker problems
I’m working on a feature shot in mini DV. The film was originally shot at 720X480 59.94i. I’ve uprezzed the footage to 1280X720 and converted the frame rate to 23.976. I’m including this info in case it has some bearing on my tracking problems.
I’m tracking some shots for an effect I want to attach. The comp is 23.976 as is the footage. For some reason the tracker, even though I haven’t asked it to track fields, is providing two key frames for each progressive frame. This isn’t the problem, but again I’m mentioning it in case it helps figure the problem out.
Anyway, the tracker seems to work. But when I apply the track, the objecting I’m compositing jitters. I’ve tried all kinds of things to get a better track including tracking both ways and averaging the tracks, but still get this jumping result.
Any ideas why this might be happening? Anything I can do? Is the tracker in AE 7 any better than AE 6.5?
Eric
Eric Goldstein
Giraffe Film Company
Los Angeles
eric@giraffefilm.com
