Activity Forums Apple Final Cut Pro Legacy HELP! Aapect Ratio PProblems with DV Animorphic
  • HELP! Aapect Ratio PProblems with DV Animorphic
    Posted by Jeffrey Fitzgerald on January 15, 2010 at 3:09 pm
    Hi Gang, I am editing a project that has clips from a movie where my client has permission to use them. In the DV Animorphic (DV Widescreen) time line obviously the film aspect is way off (It’s square pixel). I adjusted the distortion settings and scaled it just enough to look fine. So in the timeline every thing looks OK.
    But when transitions are previewed, the video is jumping up/down as if it’s switching between resolutions or something. Then on output the film clips are appearing wider than they do in the time line (I guess square pixel is stretching). I know enough to understand that there two competing sizes in play, but thought by adjusting with distortion should has resolved it. Since it looks fine when previewed (other than the transition seizures).
    Any help is much and graciously appreciated.
    David Roth weiss replied 16 years, 8 months ago 2 Members · 4 Replies
  • Jeffrey Fitzgerald
    January 15, 2010 at 3:27 pm
    I guess maybe the best question is how to convert a 720×404 / square pixel file to look correct in a 720×480 / CCIR-601 (DV Widescreen) timeline?
  • David Roth weiss
    January 15, 2010 at 5:44 pm
    If you scroll over toward the right in the FCP browser, you will notice a column header titled “Anamorphic.” Put a check mark there for each clip, then edit as normal.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
    January 16, 2010 at 2:53 am
    Thanks much. But if the video looks correct and fine with the settings now, why would everything look great in the time line and yet export wide in some sections (where the film clips are)?
  • David Roth weiss
    January 16, 2010 at 3:17 am
    I think I misread your post initially.
    If I were you, I would drop one of the film clip into a new timeline and allow FCP to match the settings to the media, and see what it does.
    However, in theory, you should be able to drop the material on the timeline and then scale without changing the distort parameter.
    David Roth Weiss
    Los Angeles
