Activity › Forums › Panasonic Cameras › help!!!
help!!!
Posted by Wizz_kydd on April 2, 2007 at 6:58 pmi shot on the the fs 100 firestore and b4 i used the organise p2 utilite in the hardrive i copied the files of without the last clip.txt and now the drive cannot reconize the clips to organise for me to import to fcp is there hope???
Wizz_kydd replied 19 years, 5 months ago 3 Members · 6 Replies -
Russell Lasson
April 2, 2007 at 10:19 pm -
D. scott Dobbie
April 2, 2007 at 11:26 pmRuss – you just guided him back to his original post.
-Scott
Russell Lasson
April 2, 2007 at 11:41 pmWell evidently nobody help him there and I sure didn’t help him by directing him to a place where nobody helped him to start with.
Sorry wizz_kydd. When I get a second I try to run a test to see if I can help.
Good luck!
-Russ
Russell Lasson
April 2, 2007 at 11:49 pmSo do you have the CONTENTS folder with all of the subfolders still?
Russell Lasson
April 3, 2007 at 12:10 amWhen I remove the text file and the CONTENTS folder is all that remains, it still imports into FCP fine. What folders/files do you have from the firestore?
-Russ
Wizz_kydd
April 3, 2007 at 3:14 pmwell all i have the the folder wit the mxf files that is on the firestore b4 ya use the oraganise util. the folder is labeled something like this (20040128-2047622-01)and that is all i have but thx 4 the help
