Activity › Forums › VEGAS Pro › help!!
  • Gary Kleiner
    November 20, 2006 at 5:11 am
    If the device shows under the Vegas Capture Utility’s video menu, you may be abel to use it from there.
    Otherwise, use the device as always and then use the media in Vegas.
    Are you converting analog footage?
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Eduardo Aiex
    November 20, 2006 at 10:00 am
    Yes gary…
  • Eduardo Aiex
    November 20, 2006 at 10:06 am
    gary the device it is there but not working in video device…i tried to select it but nothing happen, so i dont understand…
  • Stefan Voss
    November 21, 2007 at 3:07 am
    Same here! Trying to capture video in Vegas 7 via the Pinnacle Moviebox as well. Vegas 7 ‘sees’ the device but I get this error message: “The video device “Pinnacle Moviebox Deluxe” cannot be opened…” Not sure how to solve this.
  • Mike Kujbida
    November 21, 2007 at 12:21 pm
    You can’t. The Pinnacle Moviebox does not work in Vegas.
  • Stefan Voss
    November 21, 2007 at 3:11 pm
    Thanks Mike! That’s too bad 🙁
    What would be the best way to capture video in Vegas 7 from my analog Sony Camcorder?
  • Edward Troxel
    November 21, 2007 at 3:37 pm
    Get a convertor that connects to the computer via firewire. There are many available. The Canopus ADVC series is an example.
    Edward Troxel
    JETDV Scripts
  • Mike Kujbida
    November 21, 2007 at 3:41 pm
    If you own or have access to a miniDV camcorder WITH the pass-through feature (analog in to firewire out) AND your computer has a firewire card in it, this is the easiest way.
    Failing that, the Canopus ADVC-55 ($220 at B&H) is a a standalone box that does the same thing.
    Once again, your computer needs a firewire card.
    What some folks have done is to buy a used camcorder from EBay.
    It doesn’t make any difference if the tape transport doesn’t work as all you need it for is the pass-through feature.
    Be advised that not all miniDV camcorders have this feature so buyer beware.
  • Stefan Voss
    November 29, 2007 at 3:28 pm
    Mike et al:
    I bought the Canopus ADVC-55 and it works like a charm. Thanks for the recomendation. It shows that it’s often a waste of time time to get certain things to work. You’re better off making the investment and buying the right stuff! Moving from Pinnacle to Vegas was certainly the right move 🙂
    Thanks to all of you!
    Stefan
