  • Posted by Stefan Kroesbacher on November 15, 2007 at 11:03 am
    Hi all,
    so, i have a problem…
    i imported a clip with 23.98 into a 25fps timeline (i thought it was 25, but color did export it wrong..)
    After i realized that the clip was 23.98 i replaced it with the 25fps version, and adjusted the timeline accordingly and started doing CC and edits
    So, now FCP seems to be lost in “frame wars”
    what it does is take the 25fps clip, interprets it as 23.98, and play it as 25 again
    making the movie stutter…
    all settings are at 25fps.. really ALL!!
    Are there any preferences i can change that i haven’t already???
    Or do i really have to start with a new sequence, leaving me applying all the edits and
    CC’s again, because simply copying into a new sequence doesn’t solve the problem..
    Any ideas??
    thanx
    Stefan Kroesbacher replied 18 years, 10 months ago 2 Members · 2 Replies
  • Chris Poisson
    November 15, 2007 at 1:19 pm
    Stefan,
    Assuming you are using FCP 6, it will change the sequence setting to the first clip you put in it, unless you tell it no. You might try going to the sequence pulldown and changing all your settings back.
    If that doesn’t work, make a new sequence and copy and paste into it. Or start over.
    Have a wonderful day.
  • Stefan Kroesbacher
    November 15, 2007 at 2:04 pm
    thnax for the info,
    but i tried all of your suggestions!
    changing settings, copying etc,
    everything useless..
    thanx
