Activity Forums Adobe After Effects HELP….
  • Posted by Eric on September 12, 2005 at 3:48 pm
    hello, is there any way in AE to output animated masks as a movie…..I would love to have animated masks to import into maya….can this be done as a flash file??? I need to eps data for maya.
    John Cuevas replied 21 years ago 2 Members · 1 Reply
  • John Cuevas
    September 12, 2005 at 5:00 pm
    Not sure how maya works, can you key or use matte channels in it? If you can, you could use a white solid with the mask applied to that, render it out and use either an alpha channel or luma key to pull it off.
    Perhaps someone with more maya/AE experience will be able to help you.
    Good Luck and Good Editing
    johnny cuevas
