Activity Forums Apple Final Cut Pro Legacy HELP 16 x 9 format muddle
  • HELP 16 x 9 format muddle
    Posted by Babcut on July 19, 2005 at 1:12 pm
    Hi all,
    Okay, I think I ‘ve tried everything and I am totally lost. My source material is DV shot 16×9. I loaded the
    material in offline resolution (not the anamorphic). No matter what settings I use, I can not seem to find
    one that will give me a sequence I can play in real time. The clip properties say that the offline is JPEG
    resolution square pixel. I’ve tried making the sequence square pixel to match it, anamorphic on and off
    and everything gives me a tiny frame within the canvas that needs to be rendered. I’ve never worked in
    the offline format before. What am I doing wrong?
    Thanks, Barbara
    Babcut replied 21 years, 2 months ago 2 Members · 3 Replies
  • Babcut
    July 19, 2005 at 1:23 pm
    Me again. I found a solution but is it a solution or a work around? I made my sequence frame size 320×240
    to match the source material. Is there another solution or did I find the only one?
    Thanks again, Barbara
  • John Burgan
    July 19, 2005 at 1:31 pm
    320×240 is the right size. You just need to use the default Offline RT Anamorphic Easy Setup and there will be no need to fiddle around at all with settings.
  • Babcut
    July 19, 2005 at 2:14 pm
    Thanks John; I didn’t realize it was an easy settings option. Maybe if I had memorized the book cover to cover….
