Activity › Forums › AJA Video Systems › Help !!
  • Posted by Jael Dex on December 12, 2009 at 7:31 pm
    Hello Guys,
    I just bought myself a AJA IO HD. Everything is just fine, works great but there is one big Problem where I Pleas need your HELP !!
    My Setup: MacBook Pro 3,06 GHZ 15 ”
    (this is the new MacBook Pro version without an ExpressCard slot)
    My Problem is :
    As soon as I load XDCAM material in final cut, and start to edit (the material is on the External Storage)
    my playback Starts to shake an the pic even stops.
    The External Storage is plugged in the MacBook Pro via Firewire 800. The AJA is plugged in the external storage.
    But soon as I copy the Raw material on the mac HD and start to edit ti, it works just fine.
    = it seems that the external HD is just too slow using it together on one port wit the AJA IO HD.
    Is there another possibility to avoi this PROBLEM ??? Pleas I need your help .
    The mac is just 3 months old / I don’t wont to buy a new one 🙂
    THX for ur HELP (and sorry for my bad English)
    Alen
    Fred Jodry replied 16 years, 9 months ago 3 Members · 5 Replies
  • Jeremy Garchow
    December 12, 2009 at 8:11 pm
    Yes, it’s a problem. The iohd and FireWire storage can’t be on the same bus. Only the 17″ Mbp has fw 800 on it. Strange Apple decision.
  • Jael Dex
    December 12, 2009 at 8:29 pm
    yep I know, but how can I sole this problem. should i buy myself a ethernet external storage or a small server? PLS HELP
  • Jeremy Garchow
    December 13, 2009 at 6:46 pm
    Ethernet will work if it will sustain about 45 MB/sec.
  • Jael Dex
    December 13, 2009 at 11:40 pm
    First of all, I want to thank you guys for helping me out.
    Been looking around for some external Storage with ethernet.
    what do you think about this “LaCie 2big Network” ??
    May that be the solution to my restless nights 🙂 )
    Capacity : 2 TB
    Interface : 1 x Gigabit Ethernet 10/100/1000 Base-TX
    Network Protocols : File Server: SMB (Windows/Mac/Linux); AFP (Mac); FTP; HTTP; HTTPS; Apple Bonjour; and BitTorrent™
    Included Disks : 2 hot-swappable 1TB disks
    Expansion Ports : 2 x USB 2.0 for additional storage, data import, and external backups
    RAID Modes : RAID 1, RAID 0
    Special Features : Wake-on-LAN: turn the device on/off from the network
    Active Directory: for integrating current users and groups of Windows domains
    Email Alerts: for general notifications, wrong utilization, and drive failures
    Administration : Easy-to-use network setup via Web browser;
    Auto IP configuration (DHCP client compatible and APIPA)
    Security Access : Various security levels: share, groups, user profiles, public, or guest access
    THX ALEN 🙂
  • Fred Jodry
    December 14, 2009 at 6:59 pm
    Easy, if you`re not sure what security files configuration and horsepower you need, borrow a unit of what you`d like to get, zero it out, prepare it, put it through it`s paces, then thoughtfully zero it out before you return it. Here`s what security filtering you need: none. You need no security file (filename) filtering to protect your files from yourself, do you?
