Activity Forums Apple Final Cut Pro Legacy Help! 10-bit ProRes422HQ problems
  • Help! 10-bit ProRes422HQ problems
    Posted by Mike Parfit on October 12, 2008 at 12:19 am
    Hi, All,
    I need a little help, please,
    I am rendering out a ProRes422HQ timeline using the high precision YUV option in the sequence settings menu.
    When I render this way, some highlights turn into little areas of bright blue, sometimes speckled, sometimes solid. These are highlights that do not go beyond 100 IRE on the FCP and external scopes, and in most cases are well below. They don’t disturb FCP in the range check view either. These clips have a modest amount of color correction applied using the 3-way.
    These areas of blue never appear if I render the clip or timeline in 8 bit.
    I have searched here and found no references to this. Is anyone else experiencing this? If so, how did you fix it? Is there anything we can do here? I have tried applying the broadcast-safe filter, but the same thing happens.
    This problem has occurred before and after updates to the software. It has happened every time we have tried to render ProRes422HQ in high precision YUV.
    FCP 6.0.4., OS 10.5.5, QT 7.5.5 Mac Pro, 10GB.
    Mike
    Chris Borjis replied 17 years, 11 months ago 7 Members · 9 Replies
  • 9 Replies
  • Jeremy Garchow
    October 12, 2008 at 3:48 pm
    A couple of things pop in to mind.
    What’s your source footage?
  • Mike Parfit
    October 12, 2008 at 7:31 pm
    Thanks for writing,
    The source footage is varied. Most of it is HDV captured through SDI into ProRes422HQ. Other stuff is DV uprezzed to ProRes1080i using Compressor. One clip that really suffers is a high resolution still.
    In addition to the problems above, I’ve also noticed that some clips have a few places where other colors, mostly green, pop up here and there — not necessarily at the brightest parts of the picture, and again only when rendering in 10 bit.
    The timeline is ProResHQ at 1080i 60.
    Thanks for any help you may have,
    Mike
  • David Roth weiss
    October 12, 2008 at 8:00 pm
    Mike,
    Change the compressor to ProRes non-HQ, then re-render, and see if that helps. If not, then try capturing a bit at non-HQ quality and see if that helps. I recommended this to another user and it seemed to cure similar issues.
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Mike Parfit
    October 12, 2008 at 9:13 pm
    Hi, David,
    Thanks. We don’t have any problem getting a rendered clip or creating a timeline that renders fine — as long as we don’t render in 10-bit. I’m not sure how much we give up by going to non HQ, but my guess would be it could be the same level of loss (but not the same kind) that we get going from 10 bit to 8 bit with the HQ stuff. We get an instantly visible difference in image quality in some kinds of images when we render with 10 bit. But if we’re going to get these kinds of artifacts in some of the shots, that makes the whole thing questionable.
    The problem only happens with 10-bit rendering, not with ProResHQ in 8-bit. That is what seems puzzling.
    Mike
  • Todd Dalton
    October 12, 2008 at 10:45 pm
    You mention the rendering in YUV, have you tried rendering in RGB (as in the timeline options page)? I’ve had similar where my graphics card couldn’t handle rendering certain fx in YUV – full green screens instead of colourful pictures and the like. Switching the option to RGB gave me an output… Not that it guarantees legalised pictures! Had to be careful about that 🙂
    T
  • Rafael Amador
    October 13, 2008 at 5:05 am
    Mike,
    The Nattress Chroma Smooth/Sharpen Filter will be helpful for your 4.2.0/8b footage going 4.2.2/10b.
    I had some times a strong electric-blue in dark areas when using the 3W-CC. No problems with Colorista.
    Rafael
    http://www.nagavideo.com
  • Jeremy Garchow
    October 13, 2008 at 9:25 am
    [Mike Parfit] “One clip that really suffers is a high resolution still. “
    Make sure that your stills are RGB and not CMYK
  • Connie Simmons
    October 13, 2008 at 2:41 pm
    Hi. I had a program (HD Cam footage imported through AJA IOHD into ProResHQ) and I used many high resolution stills. I also tried to render in YUV high precision. I had different things happen to the renders of the stills(black screen instead of still, strange color, so I ended up 1) taking those stills and handles and putting them in a timeline where I changed the settings to 8-bit YUV), 2) rendering them, and 3)exporting them as a QT movie, current settings (no Audio), and then 4) importing them into my timeline as a clip.
    A pain but seemed to work. I am still not sure if there is a difference in final quality of the 8-bit and 10-bit YUV high quality rendering setting.
    Best, Connie
  • Chris Borjis
    October 13, 2008 at 4:12 pm
    mike do you have the render setting for 32-bit high precision yuv?
    that has been a problem for me everytime I use it no matter the codec.
    try putting it at 10-bit or 8-bit, one of those should get you through.
