Activity Forums VEGAS Pro Helo: How to make a shadow?
  • Helo: How to make a shadow?
    Posted by Tong Sydney on June 25, 2015 at 12:39 pm
    Hi
    I am new to Sony Vegas (using Trial pack). I am trying to do this clip.
    https://tinypic.com/r/14sp2x3/8
    1. I managed to get a sky and moving clouds
    2. Then I used the Mirror effect (Top)
    3. Then I mask a person and position him somewhere in the middle
    4. Then I used a Mirror effect (Top) again; and adjust the length of the effect.
    5. But I don’t want the mirror effect of the person to be identical (color, brightness, contrast, etc,… to the original person) I prefer the reflection/shadow to be a bit darker.
    Sorry. New to Sony Vegas. Cant decide how to do it. Tried a few ways, didn’t work.
    1. Drop shadow doesn’t seem relevant
    2. Shadow effect doesn’t seem relevant
    3. I tried put a Gradient Color; that did not turn out as expected. I duplicated the clip, and try to make the top clip darker and mirror effect it. Leaving the original one at the bottom. All my clouds turn black.
    4. I tried to flip the mask horizontally; but it doesn’t contain the image.
    https://tinypic.com/r/okos1u/8
    This is my first time using Sony Vegas. I don’t have Adobe Photoshop, After Effects, etc…unless you could recommend other free (trial) products. I tried getting Magic Bullet (the tech support said my graphic cards is not high enough (need 1 Giga) so when I tried using MBL, it gives an error and shutdown Sony Vegas.
    If possible, go step-by-step on any solution for the shadows; or better still a possible video so I could follow. Many thanks
    Graham Bernard replied 11 years, 2 months ago 2 Members · 1 Reply
  • Graham Bernard
    June 26, 2015 at 4:08 am
    1] Create a NEW Track 1
    2] Copy the Event to Track 1
    3] Go to this Copied Event and use Pan/Crop and Flip.
    Job done!
    Grazie
