Activity › Forums › Maxon Cinema 4D › Hello yet again guys.
Posted by Michael Munkittrick on February 25, 2007 at 9:21 amHello yet again guys.
I
Davesink replied 19 years, 6 months ago 3 Members · 3 Replies -
Mylenium
February 25, 2007 at 1:49 pmNo, spline tension is a global property of the NURBS objects. You best bet woul be to convert your shape into a polygon cage for a HyperNURBS object. You can then control creasing using edge weight maps.
Mylenium
[Pour Myl
Michael Munkittrick
February 25, 2007 at 10:38 pmBrilliant! Honestly, I was tinkering with that idea…but I wanted to verify that there was no object level control that I had overlooked.
Thanks again!
Michael Munkittrick
Gainesville, Florida USA -
Davesink
February 26, 2007 at 2:42 pmA little late in her, but if your just lofting rings, drawing a spline of the cross section and using a latheNurbs may give you the most control since you can adjust the spline and have it update dynamically.
Dave W.
