Activity Forums Apple Final Cut Pro Legacy Hello NM, and can anyone identify this effect/technique, link enclosed
  • Hello NM, and can anyone identify this effect/technique, link enclosed
    Posted by Steve Teak on January 6, 2006 at 5:45 pm
    Hi all,
    I just joined the forum, hope I can give some occational help to some… but first
    I have a clip that I am trying to find out if the effect is a known 3rd party pluggin or just some nice work with duplicate off-set and scaled layers with animated masks.Possibly animated in flash first then used as alphas?
    Any ideas would be greatly appreciated.
    Stevo
    mov link.
    https://www.pixelimage.net/ftp/ftp/Stevo/ShoreRd_clip.mov
    Tom Matthies replied 20 years, 8 months ago 5 Members · 4 Replies
  • Matthew Brunn
    January 6, 2006 at 6:57 pm
    I don’t believe this is a plugin. It appears to be two images or video of the same subject and one slightly larger than the one underneath. I would do this in After Effects but I guess you could do it in FCP. To create the effect make a sequence. Create white bars with a matte and size and animate them to suit your project. Duplicate your footage in the timeline. Make the duped footage a bit larger. Make your “animation sequence” as your travel matte luma. Hope this makes sense.
  • Greg Golden
    January 6, 2006 at 10:39 pm
    There is an After Effects tutorial here in the COW that helps you with this exact effect.
  • Jeremy Garchow
    January 6, 2006 at 11:11 pm
    I think there’s an old Motion template that does that.
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.04 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
    OS 10.4.2 <> QT 7.0.3
  • Tom Matthies
    January 7, 2006 at 2:59 am
    I did an effect almost exactly like this. All I did was to duplicate the layers, blow them up slightly and offset them. Then what I did was keyframe my crops on the top layer. Just set your vertical crops to where you want the effect to start, add a keyframe, move the timeline to where you want it to end. Add another keyframe and then reposition the crops to the ending point.I added a few more layers for the multiple effects going at the same time. Rinse and repeat. Very simple and easy actually.
    Tom
