Activity › Forums › Adobe After Effects Expressions › Hello, I have a question about the keyframe expression
  • Hello, I have a question about the keyframe expression
    Posted by ‘SMR 겜댕 on February 10, 2021 at 1:39 pm
    First of all, I apologize in advance for my unskilled language.
    What I’m curious about is I added a checkbox to the keyframe to enable on/off
    but Here I would like to know an expression to add a slider to adjust the keyframe rate
    with a slider
    Below is the expression I wrote
    I want to know where it went wrong
    if(effect(“lightwhip”)(“check”)==true){
    time*thisComp.layer(“Effect”).effect(“slider control”)(“slider”)
    nearestKey(thisComp.duration)
    else {
    value
    ‘SMR 겜댕 replied 5 years, 7 months ago 2 Members · 4 Replies
  • ‘SMR 겜댕
    February 10, 2021 at 2:43 pm
    +add
    Fortunately
    I found a way to adjust the speed at the keyframe,
    but
    I found a speed control on keyframes
    I don’t know how to add a check box expression here
    spd =thisComp.layer(“Effect”).effect(“slider controll”)(“slider”);
    accum = 0;
    for (i = timeToFrames(inPoint); i <= timeToFrames(time); i++){
    accum += spd.valueAtTime(framesToTime(i));
    value + accum*thisComp.frameDuration;
    Please let me know how to add the expression below here.
    if(effect(“checkbox control”)(“check”)==true)
  • Fabrice Leconte
    February 10, 2021 at 3:05 pm
    Place it where you need to use it
    Maybe here:
    spd = thisComp.layer('Effect').effect('slider controll')('slider');
    accum = 0;
    if (effect('checkbox control')('check')) {
    for (i = timeToFrames(inPoint); i <= timeToFrames(time); i++) {
    value + accum * thisComp.frameDuration;
  • ‘SMR 겜댕
    February 10, 2021 at 3:33 pm
    The above information was put in the expression as it is, but in the check box It doesn’t seem to work to turn keyframes on and off What should I do..??
  • ‘SMR 겜댕
    February 10, 2021 at 3:37 pm
    The position is still moving. How can it not move when the check box is turned off?
