Activity › Forums › Blackmagic Design › Hello Grant f I buy your company
  • Hello Grant f I buy your company
    Posted by Jan Bliddal on August 13, 2007 at 10:21 am
    Intensity card, will I then get a more correct colorspace If I connect that card to My Samsung monitor which is equiped with HDMI as well as DVI. Right now I am using that monitor as the Second monitor i My Final Cut Studio setup, but I was wundering If I could
    use it for colorcorrection.
    Let the machine work for you. Not you for the machine
    Kristian Lam replied 19 years, 1 month ago 2 Members · 1 Reply
  • Kristian Lam
    August 16, 2007 at 6:41 am
    Hi Jan,
    The outputs will be different. If you use Final Cut Pro and the digital cinema preview option, you’re still looking at the RGB image drawn by Final Cut Pro and not the actual video signal via HDMI (which is YUV).
    regards
    Kristian Lam
    Blackmagic Design
