Activity Forums Adobe Premiere Pro Hello everybody! Need some advice
  • Hello everybody! Need some advice
    Posted by Boris Skrbic on September 17, 2018 at 11:33 am
    Here is the thing.
    I have a flashmob footage recorded with multiple cameras. I managed to sync them and they fit perfectly.
    However, I have the original mp3 file that was played during the performance but when I import the file into timeline it appears 8 seconds longer at the end of the song. It`s going out of sync gradually towards the end of the song.
    I`m trying to figure out what could be the problem but nothing comes to mind. I`m guessing maybe bitrate or sample rate or something entirely different.
    Boris Skrbic replied 7 years, 11 months ago 2 Members · 2 Replies
  • Jon Doughtie
    September 17, 2018 at 7:26 pm
    Try converting that MP3 into a WAV file using Audition or Media Encoder. See if that eliminates the drift issue.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2017.1 (as of 8/2017)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
  • Boris Skrbic
    September 18, 2018 at 7:38 am
    Thanx for the swift reply.
    I`ve already tried to convert mp3 to .wav and .aiff with a different bit rate and sample rate, and it seems that nothing can compensate 8 seconds difference. Even the stretch tool in audition didn`t help, and although beginning and the end of the score match, everything in between doesn`t.
    It was played from a laptop with iTunes and I`m wondering if the player somehow modified the duration of the score. I`d like to eliminate this option right out, but there is a possibility. It`s the same file I`m using in premiere and it`s the first time I`m experiencing a situation like this one.
