Activity › Forums › Adobe Premiere Pro › HEEELLP! PREMIERE failure: ” \API\Inc\BE/Component/Keyframe.h-125″- ANY SOLUTION?
Posted by Serginho1957 on January 11, 2006 at 8:21 amWHAT to do when this message appears: [\API\Inc\BE/Component/Keyframe.h-125]?
No way to return to the project! What cause this problem? PLEASE HELP!
THANX from BRAZIL!Serginho1957 replied 20 years, 7 months ago 2 Members · 4 Replies -
Serginho1957
January 12, 2006 at 12:56 amHi! Thank you for reply!
I don’t use MATROX. Brand new CPU (ASUS A8V de luxe, athlon64 3200, 1gb kingston, total HDs 450gb). All was fine and, suddently, this anoying message. Newer see something like this in my old CPU. I try deinstall e reisnstall Premiere pro and plug ins. No way to open new or olders projects. I read a tip like try to reset cache settigns by press SHIFT on APPZ StartUp -no way! and don’t find the “cache” file. I’m going crazy! May I need to format my CPU? -
Serginho1957
January 18, 2006 at 6:37 amPlease some help!!!
Repeting:
No way to return open Premiere! What cause this problem? PLEASE HELP!
THANX from BRAZIL! -
Serginho1957
February 28, 2006 at 9:44 pmPlease, again! What to do when this message appears: [\API\Inc\BE/Component/Keyframe.h-125] ou “Keyframe.h-138]”? No way to open the project! I try open a new project and can’t import “corrupted” project. Only an early project version works – I must edit all again! What cause this problem? PLEASE HELP! THANX from BRAZIL!
