Activity › Forums › Apple Motion › HEEEELP! How much can motion handle
Nick Franco replied 19 years, 1 month ago 4 Members · 14 Replies
Margus Voll
August 27, 2007 at 10:19 amHi.
I’d try to make some elements not visible when not seen on the
camera. It deffinetly have helped me with combustion as it uses ram pretty much the same way. So if you make layers not visible if they are longer in time than the whole clip or they do not show at that current time then you might get more done even wit little ram.—
Margus
Nick Franco
August 27, 2007 at 2:54 pmThanks margus
we are actualy in the process of trying this out. i still have a problem of getimg the project renderd. when i send it to compressor it hangs and then falls over.
i’ve now reinstalled the system 3 times.
i’ve managed to get compresser to cluster which on every other project i have works a dream but this one is as slow as a snail.
you guys are life savers
thanks
Nick
Doyle Rockwell
August 27, 2007 at 3:55 pmHeya,
Due to the GPU-rendered nature of Motion, you can’t distribute the jobs to multiple machines using Compressor.
Nick Franco
August 27, 2007 at 5:54 pmwhat motion has to render on the graphics card to oput to PAL or NTSC?
are there any graphics cards with 5 gig of cash?i hope i’ve misunderstood
Nick
