Activity Forums Apple Final Cut Pro Legacy HEEEELLLPPP!!!! General Error!!! Project won’t open!!!!
  • HEEEELLLPPP!!!! General Error!!! Project won’t open!!!!
    Posted by Max Frank on August 2, 2005 at 4:12 pm
    This is very, very, very bad.
    I have a 118MB project file of my feature length documentary that won’t open.
    It loads to about 15% then I get a General Error!
    I’m running FCPHD on a G5 2.0 with 2.5MB of RAM.
    My start-up disk has over 20% free space and my media is on a LACIE FW800 (500GB) with around 15% free space.
    I’m up against a CRAZY deadline. Please help.
    Wayne
    2DP G5, 3.5GB RAM, FCP HD
    Max Frank replied 21 years, 1 month ago 2 Members · 7 Replies
  • 7 Replies
  • Jeremy Garchow
    August 2, 2005 at 4:26 pm
    Trash your preferences.
    G5 Dual 2Ghz <> 4GB RAM <> FCP 4.5 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
  • Max Frank
    August 2, 2005 at 4:39 pm
    will do – thanks
  • Max Frank
    August 2, 2005 at 5:47 pm
    Ok, I trashed the prefs, freed up a lot of HD space and, thank G-d, I’ve got my project back.
    Thanks for all the help.
    Wayne
  • Jeremy Garchow
    August 2, 2005 at 5:52 pm
    Cool. Now back up (duplicate) that project right now. And send it to a CD-R, firewire drive, a lock box, anywhere. That way your panic level will stay down if this happens again.
    Commence duplication.
  • Max Frank
    August 2, 2005 at 7:01 pm
    I already have – thanks – but I had already backed thhe project up to Flash and onto another FW before the problem occured – but the strange thing was that NONE of the files would open – NOT EVEN my many autosave files (I auto-save every 8 minutes) – weird.
    W.
  • Jeremy Garchow
    August 2, 2005 at 7:06 pm
    That’s because the preferences were corrupt. you can also back these up with a little application called fcp rescue (it’s free). that way if the general error happens again, run fcp resuce to restore a working set of preferences.
    Jeremy
  • Max Frank
    August 2, 2005 at 7:58 pm
    thanks again.
    Wayne
