Activity › Forums › Adobe Premiere Pro › HEEEEEEELP!!!! Problem of Compatibility
  • HEEEEEEELP!!!! Problem of Compatibility
    Posted by Jason Reitmas on March 13, 2008 at 9:52 pm
    Hey folks,
    im having a bad problem with the following content:
    i made a project with (awful!)premiere elements 4, this is what we having at school.
    but the rendering and videotranformation takes me about 10 hours and more. so i took it back home to my cs3 which is able open data, but, and here is the hook:
    it doesnt transfer it into the timeline nor does anything else!
    HELP!!!
    screen:
    https://www.bilder-space.de/show.php?file=WXZv3OLbARPt4Va.JPG
    im german, so this is the form version, but i guess you can figure out what my problem is…
    i cant be helped
    Phocas Kroon replied 18 years, 6 months ago 3 Members · 3 Replies
  • Mike Velte
    March 14, 2008 at 11:20 am
    Premiere Elements and CS3 project files are not compatible.
    Rendering times should be about the same as both apps use the same Main Concept encoder. Obviously computer speeds will influence render times.
    https://www.video2stream.com
  • Jason Reitmas
    March 15, 2008 at 10:48 am
    its not about thé matter of speed!
    the cs3 is able to open .prel files, but does not transfer them into the time line.
    so i do have the project files but certainly no project!
    i couldnt leave my stuff in school to render it such a long time , so i brought it home!
    suggestions?
    i cant be helped
  • Phocas Kroon
    March 15, 2008 at 10:05 pm
    Install Elements at home too. Costs are only EUR 100,-
    Good luck
    Phocas Kroon
