Activity Forums VEGAS Pro Heat Wave Effect
  • Heat Wave Effect
    Posted by Joao Souza on July 16, 2013 at 3:30 pm
    Do you guys know how to get that effect?
    Imagine a road on the desert and we want that heat wave right above it or even a whole city very hot which we can see a heat wave “distorting” the whole screen.
    Thanks.
    We have so much time and so little to do! / Willy Wonka
    Steve Rhoden replied 13 years, 1 month ago 4 Members · 4 Replies
  • Kelly Griffin
    July 16, 2013 at 9:45 pm
    I had to achieve the same thing last year. I used the “Dent” (or maybe it was the “Drip”) tool in Fusion and got something pretty believable with some soft masking added.
  • Steve Rhoden
    July 16, 2013 at 10:49 pm
    I know the effect you are talking, unfortunately you cannot
    achieve that effect effectively in Sony Vegas.
    Whenever i want a convincing heat wave effect, i use the
    Image Lounge plugin from Red Giant, in After Effects.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-832-4956
  • Mike Kujbida
    July 17, 2013 at 2:11 am
    Here are two suggestions from the Sony Vegas forum. Credit Rory Cooper for the first one and Spot for the second.
    #1.
    Try using the lava media gen track 2
    Colors light grey and dark grey = you don’t want it too harsh
    Set layers to max
    Frequency x 25 + – y6 + –
    Animate offset and progress very slow motion
    Add a solid white new track 1 cut a mask for your area from white = “you don’t want the heat everywhere” make this a parent composite multiply mask
    The parent track composite select displacement.
    Select flip input surface
    Drop the opacity of the mask to regulate the amount of the fx
    Your video track = 3
    #2.
    Using a height mode on an overlaid track would also create the effect.
  • Steve Rhoden
    July 18, 2013 at 9:03 am
    Well, if you dont have anymore tools to use,
    then Mike’s suggestions are your best bet.
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
