Activity Forums Adobe After Effects heat ripple
  • heat ripple
    Posted by Jessica on April 15, 2005 at 8:40 pm
    Hi everyone—
    What’s the best way to do a heat ripple (i.e. slightly distort an object with that kind of blur/motion you see on a very hot day). Would you use fractal noise?
    Thanks so much!
    Jessica
    Chris Zwar replied 21 years, 4 months ago 4 Members · 4 Replies
  • Steve Roberts
    April 15, 2005 at 8:46 pm
    Yup, use a comp containing a fractal noise layer as the map for the displacement map effect …
    … which is found in the Pro version.
    Steve
  • Filip Vandueren
    April 15, 2005 at 11:10 pm
    or the effect distort -> turbulent displace does it in one go
  • Jessica
    April 15, 2005 at 11:58 pm
    Thanks so much you guys!
    I was going to use the fractal noise and displacement map, but I’ll try it both ways now and see what works better for me.
    I really appreciate the input.
    Jessica
  • Chris Zwar
    April 16, 2005 at 2:36 am
    If you can afford it, or have the time to play with demos, then the “Tinderbox 1” set of plugins has a heathaze effect which is just gorgeous, I use it a lot. The settings can be tweaked to give a wide variety of effects including fabric rippling in a breese, not just heat haze.
    https://www.thefoundry.co.uk/
    -Chris Zwar
