Activity › Forums › Adobe After Effects › Heat Haze
  • Posted by Andrei Firtich on March 17, 2006 at 9:32 pm
    Hi, I am trying to make a Heat Haze effect. Basically I am just applying a distort map to as on a adjustment layer and taking my maping from precomped layer with fractal noise. I know people have done this effect many times. Any helpfull feedback and tips would be greatly appriciated.
    Thanks in advance
    Chris Zwar replied 20 years, 6 months ago 3 Members · 3 Replies
  • Jonathan Alexander
    March 17, 2006 at 11:15 pm
    Instead of having to deal with a precomp, you could just use an adjusment layer with the effects>distort>turbulent displacement applied to it. Fool around with the settings and animate the evolution and offset turbulence and it should do some pretty cool stuff. Hope that helps. When all you need is some basic noise like that, I feel it better to be able to have the control within that comp to easily change the distortion settings rather than having to go between that and a precomp displacement map.
    –Jonathan
  • Andrei Firtich
    March 18, 2006 at 12:40 am
    Thanks for responding, it was a little late for this project, but I tried fractal noise with some turbulent displace and it looks really nice for some clouds textures. I just animated offset and evolution on fractal and evolution on turbulent displace and I love it. I have been looking for a way to animate a cloud texture for a while, this is definatly it. Thanks
  • Chris Zwar
    March 18, 2006 at 11:27 pm
    There used to be a great tutorial on DVGarage on heathaze, but I had a quick look and can’t see it there anymore. Basically, to create a realisitic heathaze you use a particle generator to spit out red and green particles from your heat source. Then precompose and use as a displacement map. CC Particle Systems II is fine- you don’t need anything too complex, but the idea is that you use particles to represent the flow of heat in your composition- especially effective with directional sources like jet engines.
    Alternatively, there’s a gorgeous heathaze filter that comes with Tinderbox 1.
    -Chris Zwar
    Motion Graphics Designer
    Will animate for food
