Activity Forums Adobe After Effects Heat distortion?
  • Heat distortion?
    Posted by Pixelmonk on July 14, 2006 at 7:15 pm
    I’m trying to figure out a way to create a heat distortion effect in 6.5. Here’s what I came up with so far: I have an engine sequence which I duplicated, put the duplicate on top of the orignial, created a mask for the area where I want the distortion to be and tried a few different distortion plugins (stock). the closest one I came up with was Distort > Turbulent Displace. The problem is, using that effect, it doesn’t really show the heat waves moving upwards, away from the engine. I thought about using a fractal noise layer which would be keyed to move vertically as my heat distortion layer, but I don’t know the next step to make it look semi-transparent, almost glassy. I tried using it as a Displacement layer, but that didn’t seem to work to well either. Is there any way to apply the fractal layer as my distortion for the original (or even duplicate)?
    any hints would be appreciated.
    Toby Christopherson replied 20 years, 2 months ago 4 Members · 3 Replies
  • Jonathan Alexander
    July 14, 2006 at 7:22 pm
    Did you try animating the “offset(turbulence)” attribute in the Turbulent Displace Effect? Just animate the target for that attribute going up or whatever direction you want. Should give it an upward motion effect. I’m just sayin.
    –Jon
  • Aharon Rabinowitz
    July 14, 2006 at 8:01 pm
    click on my head above and it will take you to some tutorials. i did a 3 part series on displacment maps which should help you get this effect.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Toby Christopherson
    July 14, 2006 at 9:39 pm
    Clicking on Aharon’s head is my favorite passtime!
    -C13
