Activity › Forums › Adobe After Effects › heat aspect effect
heat aspect effect
Posted by Rafa Calleja on July 3, 2007 at 2:38 pmHI TO ALL, COULD ANY ONE GIVE ME ADVICE IN HOW TO SIMULATE THAT “NEBULAE” OR CLOUDY WAVE ASPECT THAT WE SEE IN SOME FILMS OR ADVS IN WHICH ACTION TAKES PLACE ON A REALLY HOOT SUMMER, ITS LIKE A BLURY DISPLACEMENT, DON
Rafa Calleja replied 18 years, 10 months ago 6 Members · 9 Replies -
Iancorey
July 3, 2007 at 3:45 pmUse Fractal Noise on a solid inside a pre-comp and set that composition as the Displacement Map Effect on your footage layer.
Darby Edelen
July 3, 2007 at 4:20 pmUsing a particle system for the displacement should work well. You can even create two particle systems, one with green particles and one with red, pre-comp them and use them with the default Displacement Map effect (red = horizontal displace, green = vertical displace) to get some interesting subtleties in the distortion.
Darby Edelen
DVD Menu Artist
Left Coast Digital
Aptos, CA -
Mike Clasby
July 3, 2007 at 4:21 pmPinnacle Image Lunge made a nifty little plugin named Mirage, but you can do a decent job with Fractal Noise and Displacement.
Details:
On a new Black Solid (Comp Size) add Fractal Noise, I used the default setting except animate the Y of FractalNoise>Transform>Offset Turbulence (Y only as you want the heat wave to slowly move upward) with keyframes over time.
Layer>Precomp the Black Solid (Move all attributes) then turn off the eyeball of the precomp.
On the layer you want the heat wave (or on an Adjustment layer, if you want several layer effected) add Distort>Displacement Map. Then choose the Black Solid Precomp layer as the “Displacement Map Layer”. You should be good to go. Adjust Fractal noise settings to get the look you want. Also the “Max Horizontal” And Max Vertical Displacement” in Displacement Map are important for the scale of displacement.
For the complete lowdown on Displacement Maps see Aharon’s three Displacement tuts, click his head and scroll down.
Brendan Coots
July 3, 2007 at 4:54 pmThis is exactly how I do it as well, right down to the red/green particles. I think I got that one from a DV Garage tutorial many years ago…
David Bogie
July 3, 2007 at 5:31 pmHeat distortion is a function of delaying and bending some light rays due to fractional differences in air density caused by heat. It is a function of refraction, not a focus effect. Whatever the source for your displacement map layer, it must be chaotic if it is going to sell the effect. Any hint of rhythm or looping and the illusion will be lost on today’s discerning audiences.
sample image of race car exhaust through super telephoto lens:
https://sleightofhand.smugmug.com/photos/163699136-L.jpgwiki entry for all kinds of optical phenomenon:
https://en.wikipedia.org/wiki/Optical_phenomenongo to the next level of abstract physics/optics:
https://en.wikipedia.org/wiki/Schlieren_photographybogiesan
Mike Clasby
July 5, 2007 at 5:03 pmWhile pedantic additions may be needless, they can be extremely interesting, Thanks.
