Activity › Forums › Adobe Audition › hear me roar
  • hear me roar
    Posted by Norman Frizzle on January 26, 2006 at 1:12 pm
    I want to as nearly as possible eliminate wind roar.
    I understand that AUDITION 2.0 has a tool similar to PHOTOSHOP’s ‘healing’ tool so if I use the lasso to isolate the roar, I can remove the bad sound, but replace it with frequencies like those in a section of the audio track that don’t have the roar in it.
    How do I do this? Any other tips for restoring this damage?
    Ozpeter replied 20 years, 8 months ago 3 Members · 5 Replies
  • Ozpeter
    January 26, 2006 at 1:46 pm
  • Willie Toth
    January 26, 2006 at 1:50 pm
    Norman,
    For large blocks of noise the spectral view is not the way to go because it is designed to heal small single clicks or pops … Wind is a hard one because of where it is in the spectrum and you will never be able to remove it entirely and keep your audio’ integrity … If you go to the posts in AUG there are 3 tutorials and the first one deals with noise removal … What they don’t mention is that you need to only take out small percentages at a time … If you take the removal too far your audio will start to digitize and sound like it’s in a rain barrel … WILLIE
  • Norman Frizzle
    January 26, 2006 at 6:39 pm
    Thanks to you both, Ozpeter and Willie.
    I know I am better working with 16 bit than 8 doing restoration, but am I also better working with 192 than 48 KHz?
  • Willie Toth
    January 26, 2006 at 8:00 pm
    Higher sample rates have their place but I think it’s causing your problem … From my experience you really don’t gain that much using the higher setting and remember when you mix it down it will be mixed down to either 441 or 48 … If I was doing your projects I would use either 441 or 48K …….. WILLIE
  • Ozpeter
    January 26, 2006 at 9:11 pm
    Normally you’d be thinking in terms of working in 32 bits and saving in 16 bits. 8 bit files are inherently noisy. If you noise-reduce an 8 bit file, it’s a bit like copying a olde-worlde cassette recording into your PC, getting rid of the tape hiss there, then copying it back to the cassette – at which point the cassette hiss will come back. 8 bit recordings are probably somewhat worse than cassette recordings, noisewise.
