Activity › Forums › Adobe After Effects › Headscratching 3D error: Z-position
  • Headscratching 3D error: Z-position
    Posted by Filip Vandueren on August 28, 2005 at 2:29 pm
    OK,
    here’s something very strange:
    • create a new comp.
    • create a small solid (20x20px)
      give it a square mask, then delete 1 point so you have a mask that’s not symmetrical.
    • Make it a 3d layer.
    • Make sure the mask is visible in the viewer
    • scrub back the Z-position:
      you’ll see the layer grow bigger as it approaches the camera.
    • scrub it past the camera and you will see the mask re-appear and becoming smaller again, but now it’s mirrored…
    The layer is not rendered, so you only see it if it’s selected and you have show masks enabled.
    But the nag is that when you do an expression like toComp() you get a totally wrong result.
    I bumped into this when using the beam effect to connect two 3d-layers, see the thread “3D Space – line between 2 points expressions”
    Help ?
    Filip Vandueren replied 19 years, 6 months ago 3 Members · 3 Replies
  • Dan Ebberts
    August 28, 2005 at 2:59 pm
    That is strange indeed. You might want to drop a line to aebugs@adobe.com.
    Dan
  • Darby Edelen
    March 25, 2007 at 8:25 pm
    I was cruising the forums and happened upon this post, but I couldn’t recreate the phenomenon… I’m going to play around a bit more with it in the context of the beam effect and toComp()…
    I’m using AE 7.0.0.244 on Mac OS 10.4.9
  • Filip Vandueren
    March 25, 2007 at 8:33 pm
    Indeed, I was testing earlier this evening, and while the problem is no longer visualized by the mask that starts to shrink back,
    The ToComp method still gives wrong results for 3D points behind the camera.
