Activity › Forums › VEGAS Pro › Headphones and Vegas 8
  • Headphones and Vegas 8
    Posted by Rick Wise on May 28, 2011 at 10:07 pm
    I’m traveling and working with Vegas 8 on a laptop. I need to use headphones while editing so that I don’t disturb the natives. Sound works fine for everything — except Vegas. There must be some setting within Vegas I cannot find that allows playback audio to come through the headphones. Can you help me?
    Rick Wise
    director of photography
    San Francisco Bay Area
    part-time instructor lighting/camera
    Academy of Art University/Film and Video (grad school)
    https://www.RickWiseDP.com
    Rick Wise replied 15 years, 4 months ago 3 Members · 6 Replies
  • Nigel O’neill
    May 29, 2011 at 12:32 am
    It could also be windows. If you are using windows 7, start Vegas then click on the volume icon in your taskbar and choose mixer. You might see the volume slider for Vegas is turned all the way down.
    Intel i7 920, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • John Rofrano
    May 29, 2011 at 12:46 am
    On my laptop, plugging in the headphones automatically cuts out the speakers. I don’t see how Vegas could override this and do anything different.
    If Vegas is using the Microsoft Sound Mapper as it’s audio device, then it should behave like every other audio application.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Rick Wise
    May 29, 2011 at 1:12 am
    John,
    All that is in place. As I said, if I go to an internet site and play a video, the audio comes through the headphones and not the speakers when I plug the ‘phones in. But the audio out of Vegas will not make a sound unless I unplug the head phones. So there has to be some setting within Vegas that is the culprit.
    I am using Windows-XP.
    Rick Wise
  • Nigel O’neill
    May 29, 2011 at 3:17 am
    Rick
    Do you get the same behavior from the rear headphone jack as well? Most modern systems have one on the front panel and one on the rear. If it works for one but not the other, the problem is most likely in the audio hardware setup (typically a RealTek device) or the software that controls it, not Vegas.
  • Rick Wise
    May 29, 2011 at 3:59 am
    I am working with a Macbook Pro/Bootcamp. The rear hole does not cut out the speaker sound. The front does — but when running Vegas does not produce sound at all. Yes, I have RealTek and I’ve gone there too with no success.
    Rick Wise
  • Rick Wise
    May 29, 2011 at 10:51 pm
    Problem solved: For some reason the headphone jack is only picking up one side of the stereo program, the right side. Vegas seems to be sending the mono signal only to the left side, even though both left and right channels are showing on the timeline. Anyway, by changing ghe “mix” in audio manager so that the left side is pushed, I have audio good enough for the simple voice edits I’m making. No more bothering the natives.
    Rick Wise
