Activity › Forums › Panasonic Cameras › headphone reverb problem
  • headphone reverb problem
    Posted by Accountclosed on June 27, 2005 at 5:41 pm
    hello all. when i plug in my headphones and listen to audio when recording on my dvx100a, the audio has a reverb problem. does anyone know of this or how to fix it? thanks in advance.
    Barry Green replied 21 years, 3 months ago 2 Members · 1 Reply
  • Barry Green
    June 28, 2005 at 6:49 am
    It happens in the progressive scan modes — the slower the frame rate, the more the echo.
    It happens because the audio needs to be delayed by two frames before being written to tape. So what you’re hearing through the headphones is 1/12 second delayed. You’re hearing “reality” and the 2-frame-delayed recording, and that’s what causes the echo.
    The only way to “fix” it would be with noise-blocking headphones that block any live sound from leaking into the headphones.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available at https://www.dvxuser.com/articles/dvxbook/ and at Amazon (https://tinyurl.com/54u4a)
