Activity Forums Apple Final Cut Pro Legacy He wants a PAL version of the NTSC DVD?
  • He wants a PAL version of the NTSC DVD?
    Posted by Kent Beeson on September 22, 2008 at 4:19 pm
    So, I know I have to make all assets PAL – how? Do I simply turn all FCP 6 timelines into PAL, then export QT’s self-contained into Compressor, keeping them PAL, then into DVD SP 4?
    K
    web.me.com/kbcv
    Rafael Amador replied 17 years, 11 months ago 6 Members · 10 Replies
  • 10 Replies
  • Chris Borjis
    September 22, 2008 at 5:06 pm
    He’s crazy, thats what he is!!
    kiddin, Kent.
    what I would do is export all of the assets our of final cut
    and do a compression for DVD and convert to PAL DVD in the process.
  • Kent Beeson
    September 22, 2008 at 5:20 pm
    Thanks for reply – so are you saying simply export the NTSC timelines into QT mov’s, bring those into Compressor and encode in Compressor to PAL, bringing those into DVD SP?
    K
    web.me.com/kbcv
  • Chris Poisson
    September 22, 2008 at 9:19 pm
    Yes, that’s what you do, but after you load the preset, check your framing to make sure it’s not cropped in a way you may not like. I do this in Episode, which is really good.
    Have a wonderful day.
  • Kent Beeson
    September 22, 2008 at 9:30 pm
    Thanks for al the helpful advice guys…
    K
    web.me.com/kbcv
  • Rafael Amador
    September 22, 2008 at 11:46 pm
    And why they want a PAL version of an NTSC DVD?
    In PAL-land the DVD players can read NTSC discs too.
    The most of the DVDs we rent are NTSC and here nobody notice nothing.
    Rafael
    http://www.nagavideo.com
  • Kent Beeson
    September 23, 2008 at 12:00 am
    Thanks for the help – well, it seems that if the DVD is “region-free” then it’ll play any where, even though it’s NTSC…can everyone confirm? If this is true, then why would anyone transcode ever again?
    K
    web.me.com/kbcv
  • Nils Crompton
    September 23, 2008 at 12:20 am
    Its ‘kinda’ true. ‘Most’ PAL DVD players will play NTSC. Some need to be set up to output a PAL signal to the TV. For instance, my DVD player used to output an NTSC signal to my TV, which was PAL only, until I changed the settings.
    So it is a ‘to be sure’ situation.
    Nils
    Macpro 8core 2.8GHz 4GB RAM 1TB RAID
    Latest OS latest FCP
    Blackmagic Intensity Pro
  • Larry Asbell
    September 23, 2008 at 2:13 am
    [Kent Beeson] “If this is true, then why would anyone transcode ever again?”
    1. To edit footage into a program of a different standard,
    2. to distribute on tape,
    3. to broadcast it,
    4. to distribute a PAL program in NTSC countries where DVD players don’t play PAL.
  • Kent Beeson
    September 23, 2008 at 2:18 am
    Thanks Larry..I should’ve been more clear, I meant why would we need to transcode any NTSC material into PAL for a DVD if it will play well in PAL-land whether NTSC or PAL. Main point being, is this indeed true? If so, neither I nor anyone needs to go through this conversion process for the above scenario…if I understand correctly.
    K
    web.me.com/kbcv
  • Rafael Amador
    September 23, 2008 at 3:32 am
    They simply don’t do it. They transcode NTSC to be broadcasted in PAL.
    No need to do it with DVDs. Extract a PAL video signal from a NTSC DVD on the fly is not difficult.
    MiniDV PAL camcorders can play NTSC tapes as well. Is not a full standard signal but in the monitor plays fine.
    As I said all the Hollywood films distributed in PAL land they are NTSC.
    Rafael
