Activity › Forums › Panasonic Cameras › HDX900 Shutter and Record problems
  • HDX900 Shutter and Record problems
    Posted by Sarah Hodgetts on May 19, 2010 at 11:36 pm
    Hey,
    I’ve just shot a comedy on a HDX900 and come across a few faults that I wonder if anyone else has come across?
    1. Shutter set to 50 but will randomly ‘jump’ to other shutter speeds and back again throughout a shot. This happens intermittently and we are unable to reproduce it.
    2. After a day of shooting, one of the tapes has nothing on it (the only one I didn’t review on the day! – Bugger!!). I’m not sure if its possible but this seems to relate to the wide-angle lens as on another tape I have the shots used from another lens, but not the wide.
    I have recorded something onto the same tape using the same wide this morning and it plays back fine….what the hell happened??
    If anyone has any ideas about these two problems I would love to hear from you,
    Cheers!
    Sarah
    Jeremy Garchow replied 16 years, 4 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    May 20, 2010 at 2:04 am
    Ghosts?
    Sounds like someone mishandled a tape.
    As far as shutter speed switching, what do you mean by 50? 1/50?
    What is the evidence it’s changing?
  • Sarah Hodgetts
    May 27, 2010 at 7:15 am
    Mishandled a tape..as in… ? Any other details or your own experiences appreciated.
    The evidence of the shutter speed change is the top left-hand corner shutter icon changing (which should normally not be there at all for the way I had set it), rapidly jumping to other shutter speeds at different ends of the scale, and the picture changes accordingly.
    If you have any bright ideas I would be interested to see if people think this might mean replacing the switch, replacing boards, or replacing the camera!
    Sarah
  • Jeremy Garchow
    May 27, 2010 at 6:17 pm
    [Sarah Hodgetts] “The evidence of the shutter speed change is the top left-hand corner shutter icon changing (which should normally not be there at all for the way I had set it)”
    How did you have it set? Are you sure you aren’t talking about the aperture?
    [Sarah Hodgetts] “Mishandled a tape..as in… ? “
    Meaning, the only tape you didn’t check is the only one that was messed up. That is a convenient coincidence. My thinking is that you had a blank tape when you thought you had a shot tape.
