Yes, look at the control panel on the smart side at the rear of the camera. there is a section labeled “video out” in that section one of the switches has 3 positions labeled 1)HD-SDI 2) SD-SDI and 3) VBS. Put the switch in the VBS position, then go out of the video out port and into the OB monitor. Works like a charm.
