Activity › Forums › Panasonic Cameras › HDX900 Firewire port
Jordan Livingston
June 20, 2006 at 5:40 pm[gary adcock] “The HDX900 lays 1080i60 to tape– so the format on the firestore would be the same.
You would have to use the pulldown removal in your NLE to get to a 23.98 psf video file.”I am currently using Final Cut Pro as my NLE. If I recorded 1080i60 as you described, do I then CinemaTools to remove the pulldown? Will the resulting footage be the same as if I recorded 1080 23.98 in camera? What are the timecode issues for this workflow if I later need to recapture lost media from the tape backups? Thanks in advance for your time and answers!
– Jordan
Pat Mcgowan
June 20, 2006 at 6:11 pmPardon me for being a bit thick Gary. Thanks for the confirmation.
