HDX900 ENG Security setting
Anyone know how to change the HDX900 ENG security setting from ON to OFF? I sometimes rent my camera, and I thought I’d check out the ON setting of this function. Goodman’s Guide said hold down the light button and then lightly press the menu button at the same time to go to the options menu. At the options menu you can change the ENG security settings. It worked great from the default OFF to ON, but the same process did not work when I tried to switch back to OFF. Only the user menu pops up, not the option menu. Panasonic manual no help.. says contact your dealer to release ON setting…great!!
If you have solution let me know .. I need to get this fixed ASAP
