Activity Forums Panasonic Cameras HDX-900 Slow Mo
  • HDX-900 Slow Mo
    Posted by Sean Fine on November 4, 2006 at 1:20 am
    I am hearing conflicting reports about the HDX and slow motion. I have a varicma and shoot alot of 60fps for slow mo. I rarely change teh frame rate other than 60. Can i do the same thing with the HDX. If so how would i do it.
    Sean
    Dave Anderson – roscor replied 19 years, 10 months ago 5 Members · 5 Replies
  • Joe Biscotti
    November 5, 2006 at 12:52 am
    The same way you have been with the Vaicam. Set the HDX to 60 and shoot away!
  • Sean Fine
    November 6, 2006 at 2:14 am
    I was told teh camera does not flag frames. If this is true woudl I still use Frame Rate COnverter on FCP to change teh 60fps into slow mo.
    Thansk,
    Sean
  • Jesse Rosen
    November 6, 2006 at 3:54 pm
    It does — just like the Varicam.
    Jesse Rosen
    Director of Technical Development
    Abel Cine Tech, Inc.
  • Robin Probyn
    November 7, 2006 at 6:56 am
    Wow so the HDX can shoot slo-mo like the varicam.Iam sure ,like alot of people ,anytime Ive shot slo-mo with the varicam I’ve shot at the maximum 60 fps.So if the same can be achieved with the 900,that must be a strong selling point.Wonder why they dont advertise it more….or is it not that simple?
  • Dave Anderson – roscor
    November 7, 2006 at 4:32 pm
    The HDX-900 flags frames identically to how the Varicam does it when the HDX-900 is operating in 720p mode. The difference is that the HDX-900 operates only at 24p, 30p and 60p frame rates (in 60Hz areas) while the Varicam is fully variable from 4-60fps. So if you
