Activity Forums Panasonic Cameras HDX 900 / Operations menu
  • HDX 900 / Operations menu
    Posted by Andrew J. cifelli on February 28, 2008 at 6:58 pm
    Guys,
    I’m trying to get the camera to read 3200K with the b filter
    in place with pre-set and 5600K when the C filter is rolled into place. I have investigated the operations/awb menu and I keep getting this flip-flop that won’t hold even after writing to the SD card. What the…?
    Thank you, again.
    Dow Haynor replied 18 years, 6 months ago 2 Members · 1 Reply
  • Dow Haynor
    February 29, 2008 at 9:56 pm
    Try this
    You can set the A and the B to 2 different color temps. Just keep it in the B Filter and set the 2 settings and switch between the 2 without rolling the filter wheel.
    If you want it to read off the card you have to set it up in the card read/write select section.
    Hope that helps
    Dow Haynor
    DP/CamMate Owner
