Activity Forums Panasonic Cameras HDX-900 embedded audio
  • HDX-900 embedded audio
    Posted by Jim Mulleder on June 24, 2010 at 12:15 am
    Hello all,
    I am looking at renting an HDX 900 for a client and they need SD-SDI out of the camera with embedded audio, is this possible or is it a tricky thing to do with the HDX?
    Thanks so much,
    Jim
    Jim Mulleder
    Level Horizon Productions
    Cameraman/Editor
    778.888.4336
    Jim Mulleder replied 16 years, 2 months ago 2 Members · 2 Replies
  • Scott Stoneback
    June 25, 2010 at 6:52 am
    SD SDI is quite possible out of the camera… it is controlled by a switch near the audio settings, for the video out BNC.
    Audio is embedded in the data stream. Timecode is not embedded in the data stream, so be aware of that gotcha.
    I use SD SDI out of my HDX900 when recording SD files into a NanoFlash recorder. It works well, save for the lack of timecode out of the SD SDI stream.
    Cheers.
    Stoneback Video Productions
    Lighting Cameraman
    Panasonic HDX900
    San Francisco Bay Area and Worldwide
    415.806.6083
    http://www.stonebackvp.com
  • Jim Mulleder
    June 26, 2010 at 5:58 am
    Hi Scott,
    I have heard about the lack of TC, thank you for that. I am new to the SDI out with embedded audio feature. Very nice. I did a SD-SDI output to Argentina from Vancouver BC yesterday…all good with the HDX. Very impressed with it.
    Thanks for taking the time to respond,
    Cheers,
    Jim
    Jim Mulleder
    Cameraman/Editor
    778.888.4336
