Activity Forums Sony Cameras HDW Close Captioning
  • HDW Close Captioning
    Posted by Earle Nichol on August 29, 2007 at 2:59 am
    Hey guys,
    I had a suprize dropped on me today…I was supposed to be getting a EEG CC encoder delivered & the Evertz HD9084 showed up. I got it working fine….except I can’t get the HDW1800 to record the 708 Close Captioning…I’m pretty sure I read some where that there is an engineering setup to set the deck to recognize the CC coming in…does anyone know how to get into the engineering setups on this deck?
    Any direction would be great!
    thanks
    pearl
    Earle Nichol replied 19 years ago 2 Members · 2 Replies
  • Steve Wargo
    August 29, 2007 at 6:17 am
    Contact Jeff Cree at Band Pro jeff.cree@bandpro.com
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
    Sony HDCAM F-900 & HDW-2000/1 deck
    5 Final Cut Pro systems
    Sony HVR-M25 HDV deck
  • Earle Nichol
    August 29, 2007 at 3:15 pm
    Hey Steve,
    thanks for the contact…I got a hold of Seth at Sony in Canada,
    Heres the deal for those that care:
    to get into the Maintainence menu on the HDW 1800 press alt/delete and F9 on front panel.
    then scroll to M3 – others menu push “set”
    then scroll to M3B push “set”
    then you will see a screen that has “ANC1” on the left nad LN1, LN2, DID, & SDID along the top.
    The multi wheel will scroll you left to right & holding down shift on the front panel will allow you to change the number settings below each column.
    All changes are made to the “ANC1” row.
    under LN1 the number should be 009
    under LN2 the number should be 572
    under DID the number should be 061
    under SDID the number should be 01
    Then hit set, and you should be good to go….wheeewf
    More learning…either tougher brain cells or less of them
    thanks
    pearl
