Activity Forums AJA Video Systems HDW-1800 Artifacts
  • HDW-1800 Artifacts
    Posted by Frederic Lumiere on June 28, 2007 at 6:52 pm
    Anyone experienced this before?
    Outputting 1080i60 to HDCAM tape on an HDW-1800 via a Kona 3, 4 min into the show artifacts show up. They seem to be static pixelation and increase over time eventually virtually filling the screen.
    Tried:
    – Different tapes (BCT-40HD &BCT 64 HDL)
    – Fast forwarding and rewind the whole tape before recording (stretching)
    The 4 min is consistent across different tapes.
    Any insight is appreciated.
    Frederic
    Frederic Lumiere replied 19 years, 2 months ago 2 Members · 2 Replies
  • John Pale
    June 28, 2007 at 10:24 pm
    I’m assuming the output from your kona/fcp system is clean…
    This could be a tape tension/alignment problem with the deck….when the take up reel gets to be about 4 minutes full, the problem kicks in.
  • Frederic Lumiere
    June 28, 2007 at 10:48 pm
    Cleaning the heads seemed to fix the problem.
