Activity Forums Apple Final Cut Pro Legacy HDV Workflow…?
  • HDV Workflow…?
    Posted by Zak Mussig on June 29, 2006 at 3:04 pm
    I’m very new to HDV, and I’ve already posted a few issues, that I don’t know are really inherent to the format so much as my specific project. That said, everyone here is very knowledgeable and professional (I’ve really enjoyed getting involved in the forum), so I wanted to try to start a dialogue to figure out once and for all, the best way to deal with this newer, and kinda wonky, format under different circumstances.
    I know it isn’t perfect (by a long shot), but I kinda see HDV as the Model T of HD formats… now we can all afford one. And between my own curiosities, and the thread listed below, it seems like a subject that could be interesting and make a lot of people’s lives easier.
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?univpostid=895718&forumid=8&postid=895718&pview=t
    Zak
    Walter Biscardi replied 20 years, 1 month ago 5 Members · 7 Replies
  • 7 Replies
  • Walter Biscardi
    June 29, 2006 at 3:13 pm
    Easiest way to work with HDV is get out of the format when starting Post. Edit in DVCPro HD or Uncompressed HD. Makes the editing process much smoother and faster.
    Walter Biscardi, Jr.
  • Mark Maness
    June 29, 2006 at 4:21 pm
    When you talk with the manufacturers of HDV equipment, they will tell you the same as Walter. As I have said many times before, HDV is a transport stream, not an edit stream.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Todd Beabout
    June 29, 2006 at 5:06 pm
    Hi Walter.
    Is there a way to bring HDV in as DVCProHD through FireWire? Our camera is out on a shoot right now or I’d just try it. The boss has not broken down and bought a HDV deck yet, so FireWire is the only option we are left with ATM. I assume if we had a deck we could just bring it in DVCProHD through SDI and my Kona card, but without the deck… Would you recommend transcoding the source material throught Compressor?
    -Todd Beabout
    Vazda Studios
  • Walter Biscardi
    June 29, 2006 at 5:49 pm
    [Todd Beabout] “Is there a way to bring HDV in as DVCProHD through FireWire?”
    Only if your camera or VTR could do this.
    [Todd Beabout] “I assume if we had a deck we could just bring it in DVCProHD through SDI and my Kona card, but without the deck… Would you recommend transcoding the source material throught Compressor?”
    If your camera has Component output, and most pro HDV cameras do, you can get the AJA Component to HD-SDI converter and connect to the Kona that way. No, I would NOT use Compressor to transcode. You really want to come in through the Kona card and let it do the conversion from HDV to DVCPro HD.
  • Zak Mussig
    June 29, 2006 at 6:54 pm
    So do you to have a Kona, BlackMagic DL HD card, or some other hardware to capture HDV as DVCProHD? I have a blackmagic decklink extreme, but it’s an older SD only version. Does using a capture card lead to an unavoidable digital – analog – digital conversion if your capture device doesn’t have SDI?
    We also only have cameras (no decks) to handle capturing and mastering from / to HDV, but I really want to change our workflow and avoid editing (mostly rendering) native HDV.
    Assuming I have to master a whole program back to HDV without a card that supports HD, am I looking at nesting into an HDV sequence, and putting it somewhere to render for a ridiculous amount of time?
    Is re-capturing DVCProHD from HDV source tapes reliable / frame-accurate? Are there any sketchy HDV drop out or MPEG2 issues with that?
    Thanks all for your participation, and great responses. I’m just starting to use HDV, and I really feel better about these things if I know as much as possible up front, and make good workflow plans. I’m also the new guy, and want a rock-solid defense for saying let’s change the workflow you’ve been using for quite a while.
    Thanks again,
    Zak
  • Stuart Cummings
    June 29, 2006 at 9:21 pm
    You want a Connect Le-google and you will find. Stuart
  • Walter Biscardi
    June 30, 2006 at 2:06 am
    [Zak Mussig] “So do you to have a Kona, BlackMagic DL HD card, or some other hardware to capture HDV as DVCProHD?”
    In realtime, yes. you can do this via software in FCP, but at least from an AJA Kona card, the results via software are not as good as the Kona card.
    [Zak Mussig] “We also only have cameras (no decks) to handle capturing and mastering from / to HDV, but I really want to change our workflow and avoid editing (mostly rendering) native HDV.”
    You really don’t want to do this with your camera. You’ll wear the heads down prematurely. If you’re doing a lot of editing / mastering, get a VTR.
