Activity › Forums › Apple Final Cut Pro Legacy › HDV workflow to finished HD-DVD or BlueRay
  • HDV workflow to finished HD-DVD or BlueRay
    Posted by Bob Carpenter on June 3, 2006 at 12:27 am
    I’ve been shooting in HDV for over a year now, but merely downconverting to DV for my finished projects.
    I know toshiba released the first HD-DVD player, but does anyone know what codec we are suppose to output to. to master a HD-DVD? So too Blue Ray should be out by the fall, and I’m curious if anyone has any idea for output workflow for that and is it different?
    Are we still in a holding pattern, obviously we’ll need burners for this kind of work, I’m just trying to figure out the costs involved and a timeline.
    Uli Plank replied 20 years, 4 months ago 3 Members · 5 Replies
  • Bob Carpenter
    June 3, 2006 at 12:35 am
    I’m more or less curious if we are suppose to output HDV, AIC or whatever then encode it to something else. Currently I output DV then encode to .m2v Will there be a similar process?
  • Rennie Klymyk
    June 3, 2006 at 2:11 am
    DVDSP 4 will encode your HDV to HD-DVD using the HD MPEG-2 codec. DVDSP also uses the H.264 codec for HD-DVD. Both DVDSP and Compressor will handle your assets using these codecs. You can currently burn HD-DVD onto todays red laser media with your superdrive. These are only viewable on the Apple DVD Player. Current dvd set top machines will not play them nor will Blueray Players. Current DVD red laser is burnt using 0.74
  • Uli Plank
    June 4, 2006 at 10:56 am
    You can use your HDV files directly in DVDSP 4, but only edited files from FCP, not fresh from the camcorder. It does some kind of re-arrangement of the GOPs, but there’s no recompression.
    Regards,
    Uli
    Author of “DVDs gestalten und produzieren”, a book on professional DVD-authoring in German.
  • Bob Carpenter
    June 4, 2006 at 11:33 pm
    I have a dual 2 GHZ power mac. Whats the quickest I could expect to render that project in HDV?
  • Uli Plank
    June 5, 2006 at 7:17 am
    I’ve seen something less than 20 minutes for a one hour project on that machine, even your rendering times can be longer if you are doing lots of FX. Remember, it’s no recompression, just arringing, if you are editing native HDV.
    Regards,
    Uli
