Activity Forums Apple Final Cut Pro Legacy HDV Workflow Query
  • HDV Workflow Query
    Posted by Quinn Costello on November 8, 2006 at 1:54 am
    Hi-
    We’re starting our first project working in HDV. We’re planning on doing all capturing on our G5 using the Kona Pcie Card and a JVC Pro HD video tape recorder and a Huge 2.5 TB 4GB Dual Channel Fibre Rackmount. We’re hoping to finish in HD. Here’s the rub- we’ll be running a raid array on one system and using another system as an offline unit. What codec should we capture in to be able to use Lacie firewire drives on the offline system? We’ll eventually be moving the project back to our online system and recapturing in HD. Does anyone have any workflow suggestions that would allow us to work offline on two systems and then later do a faithful online back into HD? Thanks as always for all the help.
    Quinn Costello
    Joe Moulins replied 19 years, 10 months ago 5 Members · 6 Replies
  • Walter Biscardi
    November 8, 2006 at 3:02 am
    [qcostello] “Does anyone have any workflow suggestions that would allow us to work offline on two systems and then later do a faithful online back into HD? Thanks as always for all the help.”
    Capture everything in HDV to start with and when you’re done with the offline, either recapture everything in DVCPro HD or uncompressed HD. Either way, you’re still starting out with HDV which I’m finding to be a bear to color correct. When it looks good it’s amazing, when it looks bad, it looks really bad.
    Our workflow was to capture HDV initially, but then we switched to DVCPro HD capturing through our Kona 3. We’re editing and finishing the project in DVCPro HD 1080i / 50.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Quinn Costello
    November 8, 2006 at 3:11 am
    Thank you for the reply. I don’t know that this would necessarily accomodate our system restrictions inre: to the fact that we’re editing offline on a G4 using Lacie firewire drives. How about capturing to the DV/NTSC 720 codec and then re-digitizing later on a G5 with a Raid Array. We’ll be doing our color correction, audio mixing and graphics/titles tweaking during the online. Thanks.
    Quinn Costello
  • Walter Biscardi
    November 8, 2006 at 3:18 am
    [qcostello] “Thank you for the reply. I don’t know that this would necessarily accomodate our system restrictions inre: to the fact that we’re editing offline on a G4 using Lacie firewire drives.”
    I’m pretty sure HDV files are smaller than DV files. They work fine on a laptop with a Firewire 400 drive so they’ll work fine on the G4. HDV is the most heavily compressed format I think we use, something like 25:1 compression.
    But if you really want to drop them down to DV, you can do that too, just make sure to keep everything at the exact same frame rate as the HDV originals.
  • Uli Plank
    November 8, 2006 at 9:08 am
    HDV is exactly the same data rate as DV (25 mbps), only JVC has less (19 mbps). The problem might not be the drives, but the G4. HDV needs an awful lot of processing power for smooth editing. What level of G4 do you have?
    Regards,
    Uli
    Author of “DVDs gestalten und produzieren”, a book on professional DVD-authoring in German.
  • Zak Mussig
    November 8, 2006 at 2:35 pm
    I’m with Uli on this one. I wouldn’t even attempt to edit HDV on a G4. Set your video device to down-convert to DV for output. Work in DV. Maybe you’ll have an opportunity to online to DVCPro HD.
    Zak
    Zak
  • Joe Moulins
    November 8, 2006 at 4:44 pm
    Quinn, take a look at my post about workflow below. In my case, we want to both avoid editing HDV, and converting to DVCPROHd (only because we’re required to deliver HDCam SR, which I didn’t point out in my original post).
    Might work for you?
