Activity › Forums › Apple Final Cut Pro Legacy › HDV using DecklinkHD (Dual)
  • HDV using DecklinkHD (Dual)
    Posted by Paul Ingvarsson on September 12, 2005 at 9:41 pm
    I have a problem with not being able to print my HDV sequence to HDV tape. Here is my setup and workflow:-
    FCP 5
    Dual 2.7 GHz G5 2.5GB
    BMD Decklink HD Dual Link Card
    I used the BMD 1080i 50 HDV easysetup to digitise all 8 hours of footage which I have cut very sucessfully on the FCP while monitoring the HD analogue component output on an HP 23″ HD display. The final destination for the project is HDCAM – which would be fine – but in the meantime I need to make an HDV approval version.
    For this I duplicated the sequence and made the AV settings HDV. When I select print to tape, FCP conforms the HDV stream and just as it’s about to play out it reports an error on playback due to dropped frames.
    The problem is that I can see the system hasn’t even tried to output to the deck before it reports this to me – any ideas what i’m doing wrong??
    Many thanks,
    Paul
    Mark Maness replied 21 years ago 2 Members · 1 Reply
  • Mark Maness
    September 14, 2005 at 4:32 pm
    You need to render your timeline. Even though it is HDv in an HDV timeline, it needs to be rendered again.
    _______________________________
    Wayne Carey
    Schazam Productions
