Activity Forums Apple Final Cut Pro Legacy Hdv to standard QT
  • Hdv to standard QT
    Posted by Jack Blandford on October 18, 2006 at 2:01 pm
    I cut a program in FCP using HVD footage.
    Some of the footage was sped up quite fast.
    When I do my usual conversion(create a sequence 720/480 and drag the hdv program in) I get lots of horizontal lines.
    How can I convert my hdv to a standard qt, leaving the aspect ratio the same and just having black bars top and bot.
    thanks
    jack
    13 replied 19 years, 10 months ago 2 Members · 3 Replies
  • 13 Create COW Profile Image
    13
    October 18, 2006 at 5:26 pm
    use compresser
  • Jack Blandford
    October 18, 2006 at 6:54 pm
    when I use compressor it pushes the hdv into the 4/3 area and makes everyone in the pict. look skinny.
    Is there a setting in compressor that keeps everything in it’s orig. aspect ratio?
    thanks
    jack
    13
    October 19, 2006 at 5:25 am
    it would help if you told us the settings you have used
