Activity Forums Blackmagic Design HDV to SD really bad motion artifacting (HELP) Prem Pro 2
  • HDV to SD really bad motion artifacting (HELP) Prem Pro 2
    Posted by Jennifer on September 30, 2006 at 1:05 am
    Newbe urgent help needed. I have captured footage off the Sony Z1 in HDV via firewire. I have done my HD edit now need to output to SD. I set up a SD project and import the .avi. Here is where the problem starts, I am getting really bad motion artifacting on the video monitor. So what are the settings when you make movie I assume that is where I am going wrong. At the moment I use Blackmagic HD 8bit codec and pixel aspect 16×9 D1. I have experimented with other settings to no avail. Please tell me where I am going wrong.
    Adobe Prem Pro 2,
    Many thanks, Jen
    Andrew Mcleod replied 19 years, 11 months ago 2 Members · 2 Replies
  • Jennifer
    October 2, 2006 at 3:16 am
    Is anyone here using Adobe Prem 2, HDV and out putting to SD?
    Jen
  • Andrew Mcleod
    October 3, 2006 at 7:28 am
    Hi
    The 1080 projects field order will be Upper field first where as NTSC 16×9 will be lower field first.
    Once you dragged you clip on to the timeline – right click . field options > reverse field dominance.
    Alternatively flicker removal can be removed by moving the entire frame 1 line at a time.
    please email – pcsupport@blackmagic-design.com if you have further issues.
    If so please include the format and workflow and the Decklink device you are using.
    Thank you.
