Activity › Forums › Avid Media Composer › HDV to SD DVD workflow suggestions
  • HDV to SD DVD workflow suggestions
    Posted by Imthinking on August 1, 2007 at 6:34 am
    I have recently started to learn on how to create DVD’s and they work fine. What for the life of me I can’t figure out is how to get that good looking HDV footage to stay that way after the transcodings and compressions. I captured 1080i via the XHA1 camera and into Avid timeline i created a quick sequence and then transcoded into Avid DNX codec and then exported via quicktime reference then in sorenson I went DVD large – VBR double pass – 6 I Frame and the video coming out just looks fuzzy like the sharpness is gone and the whites overtake the picture. I have tried every imaginable output setting and I am just very unsatisfied with the final product.
    Do you have a workflow suggestion on the settings to get the best picture to DVD from HDV for a SD delivery?
    Grinner Hester replied 19 years, 1 month ago 2 Members · 1 Reply
  • Grinner Hester
    August 1, 2007 at 3:20 pm
    If you know it’s gonna be SDI in the end, you are best off capturing it as 720 letterboxed. The resizing may be whats trashin’ your image.
    You spittin out references? I dunno whats causing the blooming.
