Activity › Forums › Apple Final Cut Pro Legacy › HDV to SD DVD
  • David Cherniske
    December 2, 2008 at 2:55 am
    I’m really glad it helped. That was my first post for anything ever. to answer your other question the HD_DVDTS file will reappear again the next time you make a project in the DVD maker. I am not sure why this happens but it does. So for now don’t worry about, it seems it cannot be destroyed. A more experienced user would probably be able to help you out on that since I have only used it a few times. At some point I will learn the proper way to deal with the problem but for now what I do gets the job done. Have a good one.
  • Steve Woronko
    December 2, 2008 at 3:54 pm
    After reading on another board. everytime you build a DVD it makes either the HD DVD_TS or Video_TS file. I knew that, but how to keep from making the HD DVD file I didn’t. Basically the solution is to start a new project and basically redo it. That worked for me. Seems that when I took over this job, the person before me had no clue what they were doing.
    thanks again for your posts.
    Stussey
    Stussey
    http://www.masscontrolmedia.com
    FCP6,DVD Studio5,Motion3,PhotoshopCS,
    Dual 2.3G G5,2G RAM,1.5TB Storage
  • David Cherniske
    January 5, 2009 at 9:38 pm
    my pleasure. Problems are difficult but you always end up learning something I guess. Hope your work goes well.
  • Aideen Johnston
    March 22, 2010 at 9:33 am
    “Basically the solution is to start a new project and basically redo it.”
    Can I just ask you how exactly you redid it without the HVDVD_TS file? I’m having the same problem and it’s doing my head in, but I’m really just about as clueless as they come when it comes to things like this so speak slowly 😉
Page 2 of 2
