Activity Forums Apple Final Cut Pro Legacy HDV to SD DVD
  • Posted by Jonathan White on September 17, 2005 at 4:13 pm
    I’ve read a few threads on this topic but can’t seem to find a satisfactory answer. Trying to make a 16:9 SD DVD out of a HDV timeline.
    I export with compressor and make it in DVD Studio Pro but always get interlaced/motion problems (strobey stuff??).
    I have the field set to top first etc. but no joy. Any definitive advice? I’m working in PAL.
    Thanks in advance,
    Johnny White
    Jonathan White replied 20 years, 11 months ago 2 Members · 2 Replies
  • Spdntckt
    September 22, 2005 at 8:44 am
    Johnny –
    I had this problem as well – What i found was that i needed to do three things to get a qualiy output in SD from HD source.
    1) Set compressor to LOWER field dominance.. i know HDV is upper.. but that setting didnt work for me in compressor 2.. lower worked fine
    2) set the GOP setting to IP. This was more of a tweak which got much better quality (at least for the material i was encoding)
    3) DONT use any VBR setting. use the CBR setting and use as high of a bit rate as you can (in my case i could use 7.5mb/s since i didnt have a very long movie – only 26 mins).
    let me know how that works!
  • Jonathan White
    September 27, 2005 at 10:12 am
    Thanks for the info. will try and let you know how I get on.
    Johnny
