Activity Forums Apple Final Cut Pro Legacy HDV to SD down-convert method in FCP?
  • HDV to SD down-convert method in FCP?
    Posted by Nigel Cooper on September 24, 2006 at 8:24 am
    I’ve shot a programme using a JVC GY-HD111E (Europe/UK/PAL), using 720p/25p native.
    In a few weeks when FCP update comes out I’ll be editing it natively using these HDV settings.
    But I want to author both an SD and a HD DVD. I’m assuming for the HD DVD I just go via compressor and DVDSP3 via HDV 720p/25p settings and master a DVD off and shelf it until required in the future?
    But what about an SD DVD, how do I down-convert the HDV progressive footage from the HDV FCP timeline to SD 720×576 widescreen footage to enable an SD DVD to be burned off in DVDSP3.
    Over on the Apple forums there are many theories for this, but most sound a little hit and miss and people over there are saying some methods produce jaggies and flickers etc.
    Is there an ultimate tried-and-tested way that yields the best quality?
    Chris Borjis replied 19 years, 11 months ago 4 Members · 4 Replies
  • Jerry Hofmann
    September 25, 2006 at 1:48 pm
    I dont’ think it’s necessary to down convert the HDV to SD before you encode to MPEG for the SD DVD. Just go straight from the HDV sequence to it.
    Choose file/Exort using Compressor… setup the SD DVD encode preset you want to use and encode.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Mactrix
    September 25, 2006 at 3:56 pm
    There seems to be a problem with FCP’s and Compressor’s downscaling
    (at least with 1080i to 576i):
    https://homepage.mac.com/b.adamski/fcpscaling/PhotoAlbum11.html
    I suggest to export a QuickTime movie, import this one in MPEG Streamclip
    and downconvert there using the QuickTime export. You can find a
    screenshot for the correct settings via the link above (you should check
    the cropping settings as these were determined for 1080i).
  • Nigel Cooper
    September 26, 2006 at 9:00 am
    I’m in the UK, shot on JVC GY-HD111 using 720p/25p settings. As I understand it FCP won’t support this right now (anyone know when?), even though I have very latest studio suite of FCP.
    So I’m not using 1080i or anything like that.
  • Chris Borjis
    September 26, 2006 at 5:29 pm
    I would export a 10-bit uncompressed hd timeline then convert it with mpeg streamclip.
    It can get the job done
