Activity › Forums › Blackmagic Design › HDV to SD 4:3 downconversion? (big doubt)
  • HDV to SD 4:3 downconversion? (big doubt)
    Posted by Loops on July 22, 2005 at 1:28 pm
    Hello,
    I would like to do a downconversion from HDV to SD, but i wolud need that the downconverted footage looked like 4:3, without letterbox. And i don’ t know if this is posible with decklink. I have checked it out with a decklink pro but it only allows me to downconvert to 16:9.
    If this wasn’t imposible i would apreciate a help. I’m going to work with a tv station, and i have to give them the master on dvcpro50 tapes. I’m going to buy a sony hdv can and i wanted to shoot in HDV and then do a downconversion with a decklink pro to print to a dvcpro deck through sdi. But i can’t wok with a letterbox image.
    Another posibility is to downconvert the hdv to dv with the camcorder and then edit to tape thorugh sdi to the deck on a dv timeline, but i don’t know if i’m going to lose too much quality.
    As you see i have a lot of doubts….
    Matthew Small replied 21 years, 2 months ago 2 Members · 1 Reply
  • Matthew Small
    July 29, 2005 at 1:27 am
    Why don’t you take your mastered HDV timeline as source and drop it into a SD sequence for the center crop version?
    I don’t know what editing system you’re on, but in Final Cut Pro, the workflow would be:
    1) Edit native HDV
    2) Create SD sequence (probably 10-bit Uncompressed)
    3) Drag HDV Master sequence into SD sequence as source
    4) Adjust DVE for Center Crop
    5) Render and output SD sequence to tape
    Matt Small
    Pair of Hands
    Sherman Oaks, CA
    “If it was easy, everyone would do it.”
